How to: Post code snippets
You can post code snippets by using the [ code ] and [ /code ] tags. However, due to how the code formatting works it cannot be used in conjunction with the ScriptSpot rich-text editor.
So, to post code I'll use the [ code ] tag to start and the [ /code ] tag to end (spaces added so it would display tag - don't use spaces).
macroScript RenameThem category:"HowTo"
 rollout rename_rollout "Enter New Base Name"
  edittext base_name ""
  button rename_them "RENAME SELECTED OBJECTS..."
  on rename_them pressed do
   if base_name.text != "" do
    for i in selection do i.name = uniquename base_name.text
  )--end on
 )--end rollout
createDialog rename_rollout 250 50
Christopher Grant
Admin, ScriptSpot.com
